drive shaft or prop shaft?
100,000 MILES
DEANTOMO
as i was driving there was a loud bang and felt like something snapped, after this i car wouldn't move in a gear, when i put the car in gear and release the clutch the prop shaft spins but makes a loud clanging noise ive had a look at the prop shaft and doesn't seem to be bent in any way, the drive shaft however has got about a inch of play when you move it back and forth ( towards the joints ) iam not sure if its the prop shaft has its clanging but still spinning or the drive shaft please help? cheers
Apr 14, 2013 at 9:20 AM
MKBARTRAM22
  • 6 POSTS
leaking transmission fluid?
Apr 14, 2013 at 9:58 AM
it sounds like you have a differential failure in the rear.
Apr 14, 2013 at 6:49 PM
