drive shaft
200,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
I am replacing the carrier bearing. There is a dust boot just behind the carrier bearing. Can i get the driveshaft apart here instead of rearend ?
Feb 25, 2016 at 2:34 AM
  • 55,858 POSTS
No you must remove it from the rear end, here is a guide that will help you.
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
Please let me know how it goes.
Mar 3, 2016 at 12:37 AM
I got the bearing replaced with no problem & im back on the road. Thanks
Mar 3, 2016 at 12:43 AM
  • 55,858 POSTS
Great to hear, thanks for getting back, please use us again and tell a friend :-)
Mar 7, 2016 at 8:52 AM
