Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mazda
b2300
Drivetrain
Drive Shaft
Replace/Remove
drive shaft
1996 MAZDA B2300
200,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
266
MEMBER
I am replacing the carrier bearing. There is a dust boot just behind the carrier bearing. Can i get the driveshaft apart here instead of rearend ?
Feb 25, 2016 at 2:34 AM
Experienced Mechanic
No you must remove it from the rear end, here is a guide that will help you.
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
Please let me know how it goes.
Mar 3, 2016 at 12:37 AM
MEMBER
I got the bearing replaced with no problem & im back on the road. Thanks
Mar 3, 2016 at 12:43 AM
Great to hear, thanks for getting back, please use us again and tell a friend :-)
Mar 7, 2016 at 8:52 AM
Add image or video
Ask a new question
Engine won't start
Engine has low power
