Drive shaft?
68,000 MILES • 7.5L • V8 • 2WD • AUTOMATIC
JIMMY ROBINSON
When I put the car in drive and give it gas there is a loud a loud screech noise and when you drive there is a vibration noise.
Sep 3, 2022 at 7:33 PM
  • 110,248 POSTS
The screech has me a bit confused. Is it loud enough for you to record and upload for me to hear?
As far as the vibration, that could be caused by a faulty universal joint. Take a look through this link. It explains how to check one.
https://www.2carpros.com/articles/how-u-joints-work
Let me know if the vibration started all at once. Also, if you can record the noise, it will likely help me.
Sep 4, 2022 at 12:52 PM
