Drive Noise
110,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
FRANKO015
My car has recently started to make a woomm ....wooommm sound when driving. The noise gets louder as I pick up speed. It has new tires and i replaced the wheel bearings {thinking that was the problem}. I am not sure what it is, maybe an alignment issue, rotors/brakes or a carrier bearing. Any suggestions would be greatly appreciated.
Apr 17, 2016 at 11:40 PM
HMAC300
  • 48,601 POSTS
it may be tires try moving front to back and see if it makes a difference. Also check the axles for broken boots.
Apr 18, 2016 at 12:31 AM
FRANKO015
I had the tires rotated and the noise was the same as before. I will check check the axles though
Apr 18, 2016 at 12:55 AM
