Drive belt noise
112,500 MILES • 4 CYL • 2WD • AUTOMATIC
DOUGLAS STRAIT
The drive belt has been replace twice in the past two years, around July each time. Last March, the squeaking noise returned. Car technicians want to replace the belt, but I have a hard time believing that the belt is wearing out every eight months.
Jul 17, 2017 at 12:37 AM
  • 55,743 POSTS
It sounds like the belt is weak causing the belt to make noise at wear out premature. Here is a guide to help you get an idea on what we are talking about. If they do not re-tension the belt after the first installation it will go bad .
https://www.2carpros.com/articles/replace-serpentine-belt
Here is a diagram (below) of what it will take on your car.
Use Bando belt, cheap belts fail quickly.
Cheers, Ken
Jul 17, 2017 at 11:49 AM
