Drive belt
STEVIE12
  • 2007 CHEVROLET IMPALA
  • 3.5L
  • 6 CYL
  • 4WD
  • 129,000 MILES
Yesterday drive belt started to make a screeching sound. I need a new belt can I drive for another two days? That is when I will have the money to repair it.
Tuesday, January 30th, 2018 AT 12:06 AM
  • 31,937 POSTS
The noise is the belt slipping, the belt tension-er may also be failing. You do run the risk of breaking the belt and being stranded on the side of the road. So if you must drive, keep the trips to a minimum and get the belt replaced ASAP and get the tension-er checked as well.
Tuesday, January 30th, 2018 AT 1:58 AM
