Draining brake fluid
1995 HOLDEN BARINA
180,000 MILES
BARINA95
I need to drain the brake fluid in my 95 Holden Barina Swing as the level got to low and the brake pedal goes to the floor. What is the correct sequence to drain the fluid? We have already tried once and lots of air bubbles came out but the pedal still goes all the way down.
May 18, 2013 at 5:16 PM
  • 31,937 POSTS
Hold pedal down and open bleeder, with pedal still fully down close bleeder, lift pedal and repeat, do all 4 wheels, in order, L/R R/R L/F R/F do not allow fluid to drop below 1/3 in master cyl. if you still have a bad pedal, you may have a faulty master cylinder.
May 20, 2013 at 8:58 PM
