Dragging noise behind front right tire
200,000 MILES • 4 CYL
STEPHANIE44
  • 24 POSTS
I knew the car had a bad rotor, but i have been driving it for weeks. today on my way to work suddenly it sounded like something was dragging on ground behind tire was also making a really loud knocking or thumping type noise. if i get over 15 to 20 mph it feels like its jerking to right. I was told the axle and CV joints are new , so i have no idea. I looked under car but nothing was dragging. Please help as this is my only transportation until i can get another car at tax time.
Dec 10, 2019 at 8:15 AM
STEPHANIE44
  • 24 POSTS
It also feels like wheel isn't turning although i assume it is because i had to drive almost a mile to get into a parking lot. In the weeks leading up to today, it would always make a grinding noise. i assumed it was because of the rotor, also sometimes it would make a popping noise if i was turning.
Dec 10, 2019 at 8:18 AM
STEVE W.
  • 15,401 POSTS
Well from the description it sounds like you had a rotor that failed and locked up the tire. If the road was damp it could easily have been drug along without making any noise. The only way to know for sure is to take that tire off and see what the damage is. Based on the description I would guess that you will need brake rotors, pads, possibly a caliper and likely a replacement tire. However it would all depend on what failed. As for the popping sound while turning, that is commonly a bad CV joint but it could have been a cracked rotor.
Dec 10, 2019 at 9:22 AM
STEPHANIE44
  • 24 POSTS
Thank you so much for your help. i m going to try to get it looked at this weekend. Is it safe to drive the car back to my house or should i get it towed? Any idea how much parts for all that will cost?
Dec 10, 2019 at 8:45 PM
STEVE W.
  • 15,401 POSTS
I would have it towed because driving it could do more damage. Parts prices vary a lot, however it also depends on what's needed and what grade of part you opt for. As an example rockauto.com shows a front brake kit with rotors, pads and calipers for about $150.00 plus shipping. Local parts store has a similar kit that is closer to $300.00. Say you needed a wheel bearing for it, those are from $15.00 - $45.00.
Dec 10, 2019 at 11:05 PM
STEPHANIE44
  • 24 POSTS
Would turning the wheel deep when i leave for work in the mornings have caused any of this? I had been asking my boy friend for weeks almost daily that the rotor is sounding really bad and making a bad noise but he never looked at it and still hasn't. but says it's all my fault the car broke down because i turn the wheel deep. just curious if this would have caused any of the issues.
Thanks,
Stephanie
Dec 11, 2019 at 6:53 AM
STEVE W.
  • 15,401 POSTS
Turning the wheel shouldn't make any difference, it's designed to be turned that far without causing damage. I would take it to a shop ASAP and have it checked over, they can give you a better idea of the problems your car has because they can see it up close.
Dec 11, 2019 at 8:50 AM
STEPHANIE44
  • 24 POSTS
Okay, thank you so much. I appreciate your help, have a great day.
Dec 11, 2019 at 9:08 AM
STEVE W.
  • 15,401 POSTS
You as well. Let us know what you find out. Please.
Dec 11, 2019 at 9:18 AM
STEPHANIE44
  • 24 POSTS
He looked at it tonight and so far he said it has a busted caliper and the rotor locked up. so you gave great advice. I will let you know if i find anything else. Again thank you very much. Have a merry Christmas.
Stephanie
Dec 12, 2019 at 10:44 AM
STEVE W.
  • 15,401 POSTS
Thank you. Hope you have a Marry Christmas as well. Please let us know of anything else you may find.
Dec 13, 2019 at 5:49 AM
