DPF and EGR removal
1,200,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
SOKRAT GEGA
  • 17 POSTS
Hi, Mr Ken, first thanks for your reply in my post I have a small service and what I do in my job is to repair and solve electrical problems. my job works fine, but I have problem in Diesel Particular Filter sector. my question is after remove Diesel Particular Filter car not works normally on road because ECU not have signals from sensor and I would intructions on how to remove from ECU Diesel Particular Filter sector. Please help, Sorry for my bad english.
Dec 7, 2016 at 3:27 PM
  • 31,937 POSTS
The Diesel Particular Filter cannot be removed and wired out of the system, it just cannot be done. the ECU requires inputs to maintain correct fuel values, so if your filter had failed, (did you try a regeneration burn?) it must be replaced.
Dec 7, 2016 at 3:32 PM
SOKRAT GEGA
  • 17 POSTS
hi,
in my country this problem remove with remapping ECU and car works fine without DPF, but cost money. in my service i have lot problems with DPF and i want to learn how to do it.
Dec 7, 2016 at 3:54 PM
  • 31,937 POSTS
here it is against the law to do this and there are no instruction available to do any such modification, so i really cannot be of any help. sorry.
Dec 7, 2016 at 5:25 PM
SOKRAT GEGA
  • 17 POSTS
Hi MHPAUTOS,
First thanks for your reply but in my country this is choice of people
because new DPF cost lot of money.
Dec 7, 2016 at 9:35 PM
  • 31,937 POSTS
i have no access to the information that you require, that info is not available as it is not permitted here, sorry i can't help you.
Dec 8, 2016 at 3:50 PM
SOKRAT GEGA
  • 17 POSTS
Thank for your reply
Dec 9, 2016 at 3:09 AM
  • 31,937 POSTS
ok
Dec 9, 2016 at 7:48 AM
