when warmed up overdrive light pops on
111,600 MILES • 5.2L • V8 • 4WD • AUTOMATIC
SCURT420
1500 sport truck downshifts fine when cold but when warmed up overdrive light pops on the right back off and then it will not downshift lower than third. i can do it manually to second but not first. governor solenoid and transducer and filter and gasket were just replaced. what could be wrong? any help on this? thanks in advance.
Apr 12, 2018 at 12:56 PM
  • 55,694 POSTS
To me it sounds like you have an engine coolant temperature sensor that is not working right. This will cause the computer to think the engine has not warmed up and then cuts off the overdrive.
It might show a trouble code but not always.
Here is a guide that help show you what you are in for when doing the job.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Cheers, Ken
May 1, 2021 at 11:06 AM
