Door compatiblily
104,000 MILES
JOHNNY RUDE2
Are 2000 Altima SL doors compatible with an 2000 Altima S?
Dec 26, 2016 at 4:21 AM
STEVE W.
  • 15,418 POSTS
Should be, but it depends on which options you have if they are a direct bolt on. For instance if you have manual windows and the replacement has power windows you would need to swap the window regulator to be able to open/close the window. Same if you had power mirrors and the replacement had manual mirrors, you would need to swap the mirrors and the wiring to make them work. Plus you need to match the doors, a two door uses different doors than a four door.
Dec 26, 2016 at 9:07 AM
