Door lock
125,000 MILES • 1.9L • 4 CYL • AUTOMATIC
CARSBY DIGGS III
(cl2 model) door drive side lock opens an all the others makes noise. Changing drive side lock would stop the other locks making nosie. Do I change all lockers?
Nov 3, 2018 at 7:21 AM
SATURNTECH9
  • 30,869 POSTS
All the other the other door locks are chattering all the time? If so see if the door lock switch on the drivers door does not return the center position? If so the spring is broken and you need a new door lock switch.
Nov 4, 2018 at 1:44 AM
