door window glass regulator
1996 FORD WINDSTAR
171,332 MILES
JASNIP
passenger door; window is in max.up position, when using the switch only a click is heard; current is available; fuse nr.40 is correct. How can I change the motor? Please with diagrams.
Thanks in advance,
Hans Snip
The Netherlands
May 30, 2013 at 6:14 PM
CJ MEDEVAC
  • 11,004 POSTS
ALL FORD STUFF IS VERY SIMILAR.....NOT HARD TO DO
THIS MAY BE BETTER WAY TO EXPLAIN...LOOK THRU THESE......THE HARDEST PART IS PROBABLY GETTING OVER THE "SCARED FACTOR"
1996 Ford Windstar Window Regulators on Youtube
PRETTY CUT AND DRY......HUH?
RETURN WITH A GRIN
THE MEDIC
May 31, 2013 at 11:51 AM
