Door trunk key
155,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
ANN KING FISHER
I bought a car used from an individual It had a key fob which works for everything just fine, but they only had an ignition key as a spare. Where can I get a key for the doors and trunk? I know they make them because I have had a Taurus before.
Nov 4, 2017 at 11:08 PM
STEVE W.
  • 15,372 POSTS
Dealer or locksmith are really the only good options. The 1999 uses the PATS-2 system. With it you need two good keys to be able to program a new key.
Locksmith or dealer should be able to program in the second key so it will work.
Nov 5, 2017 at 12:57 AM
ANN KING FISHER
Thanks Steve but both of my ignition keys work fine. It is the key to lock and unlock my door and open my trunk. I do not have one just the key fob which will do both I want an actual key for the door.
Nov 5, 2017 at 1:07 AM
STEVE W.
  • 15,372 POSTS
Sounds like the ignition must have been changed then. Should be one key for all the locks. For that you will still want a locksmith or dealer. Locksmith can cut a key to fit and the dealer could order one from the VIN number.
Nov 5, 2017 at 9:59 AM
ANN KING FISHER
Thanks Steve, I will check into that.
Nov 5, 2017 at 11:37 AM
STEVE W.
  • 15,372 POSTS
I would probably opt for the locksmith myself. Take the car to their shop, and you should have a key in a few minutes.
Nov 5, 2017 at 2:34 PM
