Door switches
80,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
BROESCHE
I have an intermittent problem with the door lock switch, window switches (driver side) and mirror control switch. I left my house this morning with all switches working. When I got to my destination, none worked, (The remote switch and the passenger side switch both work, so there is power available). When I got home this afternoon, they were not working. About thirty minutes ago I went out to the truck and the switches were working.
I am wondering if there is a loose ground wire in the circuit feeding those switches.
If you agree, where do you suggest looking? At the fuse box?
Any advice you can give will be much appreciated.
Thank you, Edwin Broesche
Sep 20, 2016 at 6:50 AM
WRENCHTECH
  • 20,760 POSTS
It is more likely that you have a broken wire in the harness at the door jam. You would have to follow a wiring diagram to test what is missing on which wire.
Sep 20, 2016 at 6:55 AM
BROESCHE
Where can I find a wiring diagram?
Sep 20, 2016 at 9:06 AM
WRENCHTECH
  • 20,760 POSTS
http://i1198.photobucket.com/albums/aa448/Wrenchtech/107265468.gif https://www.2carpros.com/images/external/107265469.gif
Sep 20, 2016 at 9:11 AM
RENEE L
  • 1,260 POSTS
Nice posted wiring diagram WRENCHTECH!
Sep 21, 2016 at 4:44 AM
BROESCHE
Thanks for the help. I was able to find a broken wire in the cable harness and spliced it back together. Everything works now.
Sep 21, 2016 at 10:36 AM
WRENCHTECH
  • 20,760 POSTS
Glad to hear we could help.
Sep 21, 2016 at 10:38 AM
