Door looks
HAAM2924
  • 15 POSTS
When any door opened there is a relay sound but without 4-lamps (orange ones) didn't turned on .
In this case What i must test ?
where is the center look system ?
my car is Verna 2000 automatic
Thanks in advanced.
May 26, 2013 at 7:19 PM
KHLOW2008
  • 41,812 POSTS
Sorry I do not understand your question. Can you please rephrase it?
May 27, 2013 at 12:36 AM
HAAM2924
  • 15 POSTS
Ok,
There is an original ceter lock in the car , when any door opened the hazard flash (rear & front) worked (be on) in the normal case. Now it is not working.
Jun 3, 2013 at 5:23 PM
KHLOW2008
  • 41,812 POSTS
We don't have any information on your vehicle so I do not know how your system works but for OEM central locking system, the flashers do not work when doors are opened except only incases when the alarm has been triggerred.
For after market alarm system, some are rigged to flash when driver door is opened, which I find a nuisance. Usually such systems can be set to flash or not to flash and requires the fob to be activated in a certain manner. You would need to check with the alarm system supplier for the provedures.
Jun 3, 2013 at 11:43 PM
