My car will lock when you put it in gear and unlock when put in park, but it will not lock or unlock with using the button on either door panel. also key fob has not worked in years. now every time you open the door the alarm goes off. I have changed the BCM and checked all fuses. any ideas? I changed blower motor resistor and got the fan going. thanks.
Feb 7, 2018 at 10:24 PM
