door locks
100,000 MILES • 2WD • AUTOMATIC
LISA VUKOVICH
My back slider doors do not lock or unlock with key fob or from driver or front passenger auto lock.( I can hear the lock) The locks will work manually. When motor is started locks click on and off.,on and off. Battery has died a few time in last couple of months. One dealer(Kia) says latches have to be replaced in back passenger doors only and maybe controllers too. Another place says all door actuators must be replaced. What should i have replaced? Latches? Actuators? Controllers? On which doors?
Apr 25, 2017 at 6:30 PM
HMAC300
  • 48,601 POSTS
if it does not cost anything let the dealer try to fix it otherwise go to a garage and he can scan for codes to see what is wrong. also, check the battery in your key fob it may be bad as well causing part of problem. Auto parts can check key fob.
Apr 25, 2017 at 11:55 PM
