Door lock switch/fob not working
10,300 MILES • 3.5L • V6 • 2WD • AUTOMATIC
RYAN1992
The door lock switches on the door won't lock the doors and the fob won't either. Replaced battery in fob and still nothing.
Mar 8, 2022 at 3:34 AM
  • 110,248 POSTS
If you can't lock them with the switch in the vehicle, there is likely a power problem. The first thing I need you to check is fuse 17 in the power distribution box located in the trunk.
In addition to checking the fuse, I need you to confirm there is power to and from it. Here is a link explaining how that is done:
I attached the wiring schematic below for you to review. Note I highlighted the fuse and many of the power supplies related. Additionally, pics 3 and 4 show the fuse location and orientation in the box.
Mar 8, 2022 at 12:35 PM
RYAN1992
It's the switch itself. I checked the relay/fuse etc., all works and the passenger one will lock all including driver. Just driver switch.
Mar 8, 2022 at 2:24 PM
  • 110,248 POSTS
I'm not sure I understand. Do the front doors lock with the switch in the vehicle and the FOB? If you have two doors working and two not, let me know. I was under the impression that none of them worked.
Mar 9, 2022 at 5:14 AM
