Door lock is stuck in partially shut
225,000 MILES • 4 CYL • 2WD • MANUAL
KATHY HAWKES
Was replacing door actuator on front passenger door. Apparently locking mechanism got pushed into locked position without me noticing. Now door will neither open or close tightly. Inside panel is off but can't access lock to release door as door will not open. Need suggestions.
Mar 30, 2019 at 6:51 AM
JOETECHPRO
  • 705 POSTS
Hey KATHY HAWKES,
Have you got the interior door handle connected?
The cable for the interior door handle should unlock/open the door.
Worth a try first.
Regards, Joe
Apr 1, 2019 at 3:11 AM
