door lights stay on when all doors are closed?
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the damaged module and connector assessed, including the cause of the damage and any moisture entry. Verify replacement compatibility and setup requirements before installation, then confirm normal lighting operation.
Guidance references and applicability
2CarPros: Original discussion 1711972 https://2carpros.com/questions/door-lights-stay-on-when-all-doors-are-closed Source for reported history and outcome. Contributor suggestions are not independently confirmed diagnoses. Attachments were not verified.
Discussion summary
The owner reported interior or door lights staying on with the doors closed. Disconnecting the BCM extinguished them. On removing and opening the BCM, the owner found burned circuit-board connections near the door-switch connector and suspected water intrusion.
Reported outcome: The owner reported visible BCM damage, but no completed replacement or final functional result.
Water intrusion was suspected rather than established. Disconnecting a module and extinguishing the lamps alone would not have isolated the fault; the later physical damage was the additional finding.
