door latch stuck in open position on rear passenger door drivers side.
12,000 MILES • 4 CYL • FWD • AUTOMATIC
BKSMILEY8300
Won't latch. How can I fix this myself?
Nov 22, 2015 at 9:31 PM
More than likely the latch was flipped at some point, and you can use a screwdriver to flip it back. Here is a guide that will help with this:
https://www.2carpros.com/articles/car-door-hood-or-trunk-will-not-close
However, the easiest way to solve this if this is the case is to just operate the interior door handle. If you open the door using the inside handle, then that will flip the latch back to the open position.
If none of this works, then we need to remove the door panel.
Here is a guide that will show you how to do it. Please run through all this info and let us know what you find. Thanks
Feb 24, 2022 at 9:58 AM
BKSMILEY8300
The latch is in the open position. And will not close. This is the answer for the closed position. Unhelpful.
Jul 15, 2022 at 4:34 AM
  • 55,649 POSTS
Yep, sorry about that. When the latch is stuck open the latch is bad and needs to be replaced. I have included the instructions on how to do so in the diagrams below. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Jul 15, 2022 at 4:38 AM
