Passenger door does not close after minor run in with a pole
1996 MAZDA LANTIS
240,060 MILES
OCER
My partner was reversing did not realize the passenger door was open the door got stuck on the pole bent it back a little bit now it does not close at all. what should I do? The door is not flush now either it seems uneven and does not close completely. have to hold door closed when driving.
Apr 7, 2018 at 2:31 AM
HARRY P
  • 2,292 POSTS
You will have to take it to a body or frame shop and get them to straighten it out. Most likely, the hinges are bent. They should have the tools to take the door off and straighten the hinges, or replace them completely.
If you are handy, you can try taking the door off and straightening them out yourself. Just use the hinges on the other side as a guide to help identify the exact trouble areas and how much adjustment is needed. A hammer and a couple of pairs of pliers would be your best friends for getting the job done.
Apr 7, 2018 at 3:44 AM
