While driving, when you come to a stop the indicator comes then goes off. Sometimes when you are turning it comes on then goes off.
Feb 23, 2014 at 4:08 AM
HMAC300
✓Experienced Mechanic
check for a broken wire at switch at one of the doors.
Feb 23, 2014 at 11:22 PM
ROBERT KELL
MEMBER
Okay, I will check. Does Toyota use mercury switches?
Feb 24, 2014 at 4:11 AM
HMAC300
I am unsure on that I kind of doubt it. normally they ground out when door is open to activate them it could be a module as well so have it scanned too.
