Door actuator
100,000 MILES • V6 • 2WD • AUTOMATIC
PATRICK GALLANT
No access do replace actuator because door is lock close.
Oct 19, 2018 at 8:02 PM
Good morning.
Has anyone tried to manually release it with a slim jim? that is where they go between the window and the door frame from outside the truck to move the rod manually.
The only other way I have accessed the inners of the door is to go in to the passenger side, remove the front seat and remove the door panel to access the release.
When the actuators seize and will not move, it makes it very difficult to gain any access.
Sometimes you can call a lock smith to see if he can at least get it open for you to save all the other work.
Oct 19, 2018 at 10:14 PM
PATRICK GALLANT
Already have the door panel out and seam like the the door does not want to unlock the rod moves but door stay locked.
Oct 20, 2018 at 1:01 AM
Which rod moves?
Can you post a picture of what you see?
Oct 20, 2018 at 2:32 AM
PATRICK GALLANT
The one to lock the door moves in the actuator and I can see the thing move inside but will not unlock the latch.
Oct 20, 2018 at 6:36 AM
From your description, it sounds like the door latch is what is not working. If the rod moves and you see it move the actuator, the only thing left is the latch.
Oct 20, 2018 at 7:19 AM
PATRICK GALLANT
Any idea how to get it open?
Oct 20, 2018 at 9:37 AM
You may need to go to the latch and manually release it. You may need a screwdriver to move it to open.
Oct 20, 2018 at 10:08 AM
