door
72,156 MILES
TYLERSTONE2510
Driver door won't stay closed
Mar 2, 2016 at 10:14 AM
CATAFINA
  • 167 POSTS
You need to look at the locking mechanism at the door-Investigate.
Mar 2, 2016 at 3:42 PM
HMAC300
  • 48,601 POSTS
Put screwdriver in door latch on door and see if latch will close manually or feels really loose. lube latch with penetrating oil then see if it will open by the handle work it a few times, then see if the door closes. If not, the latch is probably bad.
Mar 2, 2016 at 10:11 PM
