dont wanna go when given gas
128,669 MILES
ILOVERICHIE
When i start the car it runs but doea not wanna take off n dies i replaced the air filter and the fuel fillter n wen i did it startd to run alot better then it did befor it would just choke wat could b the problem?
Jun 16, 2013 at 11:11 AM
  • 75,988 POSTS
Check the ignition timing and fuel pressure if it within specification -start here
Jun 16, 2013 at 11:47 AM
DUGSMOBILE
  • EXPERT
  • 38 POSTS
Does the car run fine for a while in park/neutral then when placed in gear stalls immediatly? I have seen a few transmissions have the solenoid to the torque converter stick in the applied position which won't allow it to slip sitting still. this problem can be corrected pretty easy but need to be sure of problem. Ammco professes a free check if the answer is yes. What happened before all this began? did anyone work on it prior? were there any other things going on or did it just happen all of a sudden? Hope this either helps or gets you a little more curious. Don't give up.
Jul 14, 2013 at 3:03 AM
