Weird smell to it and it started running weird
230,000 MILES • 3.5L • V6 • AUTOMATIC
LM8301
I drove my car in second gear on the highway and i pulled over when i noticed, after i pulled over it had a weird smell to it and it started running weird. It stills turns on but i am not sure if it’s okay to drive and wondering what i can do to fix it.
May 20, 2019 at 10:41 PM
  • 110,248 POSTS
Welcome to 2CarPros.
If it is running properly now, chances are it was getting excessively hot from the higher RPM's. That could have been burning dirt and oil off the engine and exhaust.
If it seems to be running normally, you should be fine.
Let me know if there are any other things you noticed.
May 21, 2019 at 12:56 PM
LM8301
It still doesn’t run properly.
May 29, 2019 at 3:54 AM
  • 110,248 POSTS
Welcome back:
Can you describe how it is running? Is there a loss of power, rough idle, misfire and so on?
May 29, 2019 at 10:12 AM
