Engine control unit rebuilt. Now it won't start at all?
130,000 MILES • 1.6L • AUTOMATIC
THROUGHLYCARING123
Changed the alternator, fuel pump, ignition coils, spark plugs, idle air control sensor, and the battery. Ive tested all the relays with a tester and checked all fuses. Also checked injectors to make sure they are opening and closing. The car would start and run until you shut it off then it would probably start the next day. Ive had the engine control unit rebuilt. Now it won't start at all! Help?..
Jul 14, 2026 at 5:11 PM
  • 55,694 POSTS
So to be clear, the engine cranks over and will not run? Or the engine will not crank over? (starter). Let go over these two videos to help us get started fixing the problem.
https://www.youtube.com/watch?v=6YRW8fyNudY
and
https://www.youtube.com/watch?v=lXLJbuAZ4CE
Please upload a short video in your response of the problem, so I can see what's going on
Jul 15, 2026 at 9:56 AM
