Dome light and cargo light
68,000 MILES • 6.5L • V8 • 4WD • AUTOMATIC
REBELYELL21
I just purchased this pickup from an elderly couple and it only has 68,000 original miles. The dome light will not work from either the door being open or from using the switch and the cargo lights do not work either, but they are on a separate switch. I have checked all the fuses and the bulbs and they are all fine. I do have the dash apart now looking at the wiring but and trying to test the switches. Is there anything else I should be looking for before I buy all new switches?
Nov 9, 2016 at 8:58 AM
HMAC300
  • 48,601 POSTS
take a test light or volt meter see if switch gets power then when turned on see if it works if it does then you do not need a switch. he fuse is ctsy fuse 25 amp. then turn dimmer switch all the way down and see if dome light works like that. check ground wire on left hand instrument panel for no corrosion and good connection.
Nov 10, 2016 at 1:41 AM
