Cruise control stop working security light will flash and will shut off
232,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
BEARCAT2
It's just something different all the time. more you drive it the worst it gets. sometimes will not start after it gets warm security light flashes 3 time's and shuts off going down the road it will start back up but the hotter it gets the worst it gets..
Dec 15, 2019 at 12:44 PM
BEARCAT2
I also forgot the reduced power light will come on that car sometimes.
Dec 15, 2019 at 12:48 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I have a feeling the check engine light should be on to have a fault stored and put your car into "limp mode" First thing you need to do is have the fault codes stored in you cars computer. If you don't have access to a scanner/code reader most auto parts stores have a tool loaner program and can rent you one. Some auto parts stores like AutoZone can check codes for free.Here is a tutorial showing what is involved for checking vehicles codes:
After having the codes read get back to us with the code numbers and then we can properly diagnose the issues with your vehicle.Hope this helps and thanks for using 2CarPros.
Dec 15, 2019 at 1:14 PM
