radiator has a small crack in it firing but will not start
251,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
JEREMY 2O
My car ran hot and the heater quit working the fuse is blown. My car ran hot we put water in it and it ran ok for a while then quit. The radiator has a small crack in it firing but will not start.
Feb 26, 2016 at 2:03 PM
If the car ran hot due to a hole in the radiator, then we need to suspect the head is warped or you have lost compression.
If you have low or no compression, then that will cause a no start after something like this.
Also, if the head gasket is leaking then this could cause the plug to foul as well so we should check the head gasket.
Let's start with this info and go from there. Thanks
Dec 13, 2021 at 11:35 PM
