Shuts off when transmission is shifted into drive?
180,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
CHAD STEWART
The car will shut off once put into gear. Starts up and idles just fine until the car is put in the drive position.
Oct 7, 2022 at 3:44 PM
  • 55,721 POSTS
This can happen when the transmission torque converter falls apart internally. But to be sure if you upload a short video with your response I can tell for sure.
This guide can help as well:
https://www.2carpros.com/articles/stall-at-idle
Also are there any codes?
Please go over this guide and report back. I can provide how to change the torque converter out if needed.
Oct 8, 2022 at 2:56 AM
