Does the intake manifold system on this car have ONE or TWO intake manifold runner control valve ACTUATORS?
280,000 MILES • 2.3L • 4 CYL • FWD • MANUAL
JENNISU
Check engine light's on, throwing a P2004 code: "Intake Manifold Runner Control Valve stuck Open Bank 1." Additional code previously thrown was P2008... it's believe the problem malfunction with a sensor in the system's Actuator. The engine has 2 IMRCV switches...one of which was replaced in an attempt to solve the problem. With TWO IMRCV switches, would I be right to assume that there are also TWO actuators?
I'm eager to fixthe problem. Please let me know your thoughts. :)) thanks, jenni j.
Nov 10, 2015 at 7:48 AM
HMAC300
  • 48,601 POSTS
check items in pic like a sticking or binding of throttle plate so clean that on both sides with choke cleaner and iac hole then check everything except pcm . there is an intake runner control and intake swirl control. also check for a vacuum leak to actuators or on engine. one pic explains how it works it's for a ranger but similar on your car also make sure no grommets on engine are leaking inother words no air or vacuum leaks.
Nov 11, 2015 at 10:23 PM
THIS IS MIKE
  • 686 POSTS
Jennisu
November 13, 2015.
Thank you for providing me advice on fixing the problem I'm having with my 2003 Ford Focus. I so appreciate your help.
With gratitude,
Jenni :))
Nov 13, 2015 at 5:14 AM
THIS IS MIKE
  • 686 POSTS
Jennisu
November 16, 2015.
Thanks again for your continued support. Not being a mechanic, it's all a bit over my head. Is it possible that simply replacing the Actuator, the Intake Manifold Relay Control Valve Actuator, will fix the problem?
Nov 16, 2015 at 3:39 AM
