Does oxygen sensor need to be replaced
206,000 MILES • V6 • 2WD • AUTOMATIC
OHYEA
  • 153 POSTS
Checked the live data on the car and it shows that the short and long trims are at -100 and doesn't change even when vehicle is driving. I also just got the codes p0302,p0171,p1131 as well. I however did pass the smog test not that long ago to.
Apr 27, 2015 at 2:41 AM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge auto parts rent it and check for a vacuum leak as well. see pic for other things that can cause this. make sure to check all grommets, and air leaks like from air cleaner to throttle body as well and vacuum hoses.
Apr 27, 2015 at 5:28 AM
HMAC300
  • 48,601 POSTS
forgot pic
Apr 27, 2015 at 5:29 AM
