HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine
Symptoms
Not Cranking Over
Does not turn over
RPODHORA
MEMBER
2004 FORD TAURUS
3.0L
6 CYL
2WD
AUTOMATIC
155,000 MILES
Will not turn over even with a new battery and alternator.
Wednesday, October 3rd, 2018 AT 6:15 AM
KEN L
MASTER CERTIFIED MECHANIC
It sounds like the starter motor is not working but to be sure let's follow this guide to confirm the issue.
and
Cheers, Ken
SPONSORED LINKS
Thursday, October 4th, 2018 AT 11:39 AM
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
Engine Not Cranking?
Won't Start-no Crank. Dead. Radio, Lights, Heater, Etc. All Work Fine. Jumped Socket 30 Of Starter Relay To Battery And Starter Motor...
Asked by
DEEJASJR
1 IMAGE
2000
FORD TAURUS
GUIDE
Starter Not Working
This guide is designed to help you identify whether the issue with your non-working starter motor is due to an electrical problem or a fault within the starter motor itself...
Engine Will Not Crank Over?
I Went To The Store. Got Bake In My Car And All The Bells And Lights Come On But Will Not Crank. After It Sat There For About An Hour It...
Asked by
cheri410
1 ANSWER
4 IMAGES
2003
FORD TAURUS
2002 Ford Taurus No Crank
Changed Fuel Pump No Crank No Theft Light Tryed Everything Cranked Before Disconnected Battery Put Everything Back Together And No Crank No...
Asked by
toffer1982
1 IMAGE
2002
FORD TAURUS
1998 Ford Taurus Will Not Crank, But Will Turn Over
I Have A 1998 Ford Taurus And It Will Not Crank. All It Will Do Is Just Turn Over. It Was Fine The Night Before. The Lights And...
Asked by
tracyholland
1 ANSWER
1998
FORD TAURUS
Won't Crank Over? - Blowing 40 Amp Fuse F1.07?
Initial Symptom Was The Car Would Not Start. No Clicking At The Starter Was Heard. Swapped Several Relays, Still Nothing. Found The Battery...
Asked by
caranddriver
1 ANSWER
7 IMAGES
2003
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Battery Replacement Ford
Battery Replacement Toyota
Starter Motor Replacement
Online car repair manuals
