I went to start my car and it would not start at all. Also when I plugged in my scanner tool with key off I had power to it. When I turn the key to the run position I lose power to the code reader tool. I have checked three times all the fuses and relays and do not find the problem.
I even removed the battery and all the ground cables even those to the body and cleaned all the connections and checked their continuity.
Seems to be a problem with a ground somewhere as I mentioned I lose power to the code reader tool when I turn the key to the run position and lose power to the code reader tool. .
Fuel pump reset switch is not tripped either....
got any idea?
Please help...
Daniel M Crisco
dcrisco9@gmail.com
615 415 3310
got any idea?
Please help...
Daniel M Crisco
dcrisco9@gmail.com
615 415 3310
Mar 18, 2017 at 3:53 AM
