Does not have an ERG valve
99,500 MILES • TURBO • 2WD • AUTOMATIC
MICHELLE098
E 4 misfire looked and it does not have an EGR valve. It acts sluggish like bad gas. Put new plugs and wires on. what else could it be?
Apr 20, 2018 at 3:54 AM
Good afternoon.
Do you mean it has a code for cylinder four?
I would start with a compression test to see if the engine timing is off. the timing belt may be worn and loose and it will retard timing and lower compression.
Apr 20, 2018 at 3:58 AM
