does GEM need to be programmed
104,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
RKMJR.
  • 7 POSTS
Interior dome,map and courtesy lights died after leaving rear hatch open overnight a few years ago.Dash lights and headlights all other functions are good. Can I replace GEM to solve problem?
thanks a lot for reply
Feb 2, 2016 at 5:59 AM
  • 55,676 POSTS
Yes, the Gem has failed which is what causes the the problem you are describing. please let me know if it works
Feb 7, 2016 at 2:43 PM
RKMJR.
  • 7 POSTS
Does this GEM module have to be programmed,or just swapped out with proper matching unit? (2002 Ford Escape XLT 6cyl. 4WD)
Thanks again
Feb 7, 2016 at 10:04 PM
  • 55,676 POSTS
I does not need to be programmed, just switch it out.
Thanks for using 2CarPros.com
Feb 8, 2016 at 12:09 AM
RKMJR.
  • 7 POSTS
Thank you much
You have answered a question that I could never get a straight response on.
Feb 9, 2016 at 1:13 AM
  • 55,676 POSTS
No problem, that what we are here for, please come to us again anytime and tell a friend.
Feb 9, 2016 at 1:17 AM
