can a bad torque converter cause the transmission to not engage into any gear at all
139,400 MILES • 3.1L • V6 • FWD • AUTOMATIC
JO CHANDLER
My name is Jo, and I have a the car listed above that is the SE Coupe. It has 139,000 miles on it and no modifications.. It started to shift erratically a couple of weeks ago first to second gear, shuddering at low rpm. so I get home to check the fluid in the trans-axle and found debris present on the stick, but I did not change the fluid since last tune up about 6,000 prior, but the car was still operational. so I the next morning I get up for work and start it to warm up come out to leave put it in gear and head to work but turned around because I forgot my phone pull in the driveway get out while car was at idle but when I get ready to leave it would not engage in any gear at all. It did five minutes prior. When I put it in gear to leave it made a familiar rattling or roaring noise that almost resulted in stalling but it did not. I have checked all vacuum hoses for cracks, holes, and leaks there were none with no codes thrown. I have checked fluid level and all sensors are working properly with proper voltage. New strainer and gasket as well. I just wanted to know on this particular vehicle would a bad torque converter cause it not to engage in any gear at all?
Feb 26, 2017 at 10:19 AM
KHLOW2008
  • 41,812 POSTS
For any vehicle, a bad torque converter can result in no gears. Debris on the dipstick is an indication the transmission is on its way to retirement.
Feb 27, 2017 at 9:33 AM
