2008 Dodge Viper clearing trouble codes
2008 DODGE VIPER
WESTXSRT10
Computer problem
2008 Dodge Viper Two Wheel Drive Manual 800 miles
I installed an after market exhaust, the check engine light came on right away at start-up.
" My question is HOW can i clear the code or retreive the code information?
thanks
Feb 24, 2008 at 3:36 AM
BMRFIXIT
  • 19,053 POSTS
Retrieve the code and record it then clear the code and if the same code come back on
check the system u have installed
if its related to the codes
(you may just voided your warranty )
post the code here
Feb 24, 2008 at 3:58 AM
WESTXSRT10
[quote:2232fc6916="BMRFIXIT"]Retrieve the code and record it then clear the code and if the same code come back on
post the code here[/quote:2232fc6916]
Thanks for a responce but your answer appears to be the same as my question. I will try edit my question.
Feb 24, 2008 at 6:35 AM
BMRFIXIT
  • 19,053 POSTS
OK
you need an OBDII reader
cheep enough if you like to buy one
they are available on line (e bay or so )
or you can visityour local part store (like auto zone)
they can scan it for free
good luck
Feb 24, 2008 at 8:13 AM
WESTXSRT10
[quote="BMRFIXIT"]OK
good luck[/quote
I was told from a Viper Club forum member that a OBDll reader won't work on the 08's. I can not verfiy that though.
thanks
Feb 24, 2008 at 9:02 AM
BMRFIXIT
  • 19,053 POSTS
Its a federal law I think every car made on and after 1996 it has to be obd ready
sold in the USA
but then again every thing is possible
Feb 24, 2008 at 12:22 PM
VIPERTEK
  • 40 POSTS
yes read codes ,it came on right after exhaust work? probably o2sensor codes may have been damaged or eliminated from custom exhaust. o2 simulators are available
Jan 8, 2009 at 11:42 AM
