1994 Dodge Viper 1994 dodge viper wont crank, therefore won
ROBGS69
Engine Performance problem
1994 Dodge Viper 10,400 miles
Hello guys give me a hand...
Here is the deal I have 94 rt/10 viper 10k miles
I turn the key and nothing.
I have charged the battery but nothing. all the lites come on like normal the battery is fully charged.
I have had a intermitten problem with this a few times, but it always started.
It makes no crank. The procedure to start is clutch to the floor emergency break on than turn key.
My thought is that it is something to do with the clutch sensor, or something with the ignition. The car is always garaged and is 10 k miles.. Is there a comon problem with 1994 vipers? Help me o'holy ones of automotive expertise.
rob
Dec 3, 2008 at 10:37 AM
CH112063
  • 1,320 POSTS
Hello, are you still having a problem starting your car when you put the key in the start position with the clutch pedal depressed? I'm sure you have replaced or repaired the clutch normally open switch by now. The contacts get some corrosion on them from sitting and sometimes they would fail, but it was not a common problem but it was an uncommon car to breakdown in that fashion in the dealers I worked at. Do you like your car? They told me in all my Viper classes that the 94 RT/10 shuts off fuel at 163mph. That was not correct.
Aug 29, 2009 at 11:57 AM
