2003 Dodge Van Reverse light
56,000 MILES • V8 • 2WD • AUTOMATIC
SSAREMI
  • 5 POSTS
When the gear shift is on Reverse the lights do not turn on. Both lights are not working and I have looked at both bulbs and they are OK. How can I search for the problem and fix it.
Thanks,
Sam
updated 10-30-09
Hi Guys,
Thanks for your prompt respond. I understand that the back-up light switch on transaxle could be faulty. Do you have instructions and/or diagram for replacing the back-up light switch?
Oct 18, 2009 at 11:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
suspect faulty back-up light switch located at rear of transaxle
Oct 18, 2009 at 12:01 PM
BLUELIGHTNIN6
  • 16,542 POSTS
I'll see what I can find. Is this a Dodge Ram Van B1500 series or a different Van ?
Oct 30, 2009 at 7:31 AM
SSAREMI
  • 5 POSTS
It is a 2003 Dodge Ram 2500.
Oct 30, 2009 at 10:05 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Sorry, I did not realize your vehicle was equipped with an automatic transmission. The transmission range sensor (TRS) is what is used for the back-up lamps on your vehicle. It is located on the left side of the transmission and is replaced by simply disconnecting the electrical connectors and removing the sensor from its mounting location.
Oct 30, 2009 at 12:35 PM
SSAREMI
  • 5 POSTS
Do you have a diagram and or instruction dfor this repair?
thanks
Nov 1, 2009 at 11:23 AM
SSAREMI
  • 5 POSTS
Hi Guys,
I have replaced the TRS and the problem has been solved thanks to you. I appreciate your help and thanks again.
Sam
Nov 2, 2009 at 10:06 AM
