2002 Dodge Van P0748
106,291 MILES • V8 • 2WD • AUTOMATIC
NIKKIBRETT
  • 5 POSTS
I recently thru a P0748 code. Had the solenoid replaced, the relay switch, the harness and all the wiring replaced. Car worked great for 2 months and after a snowstorm it thru the code again. It goes through the shifting perfect then will go to limp mode. The transmission has been checked and is perfect. Nothing mechanically wrong with the tranny.
Is my next step to replace the PCM?
Mar 22, 2010 at 4:41 AM
DOCFIXIT
  • 18,828 POSTS
Has code been erased and came back? does light stay off until it goes into 3rd. then lights?
Mar 22, 2010 at 4:56 AM
NIKKIBRETT
  • 5 POSTS
Yes the code was erased each time and for a while the light stayed on but the car shifted like normal, then the light went off and all was fine. Currently the light is on, can't get it to go off and the car starts fine, goes about 10 miles then goes into limp mode.
Mar 22, 2010 at 5:08 AM
DOCFIXIT
  • 18,828 POSTS
The solenoid assembly was replaced? relay and wiring harness doesn't leave much but PCM. Present code P0748? any other codes present? like P1765?
Mar 22, 2010 at 7:12 AM
NIKKIBRETT
  • 5 POSTS
Everything replaced up to PCM. No other codes showing or stored. Just the P0748.
Everyone is really confused and I just have a hard time with the repair if no guarentee.
Mar 22, 2010 at 7:20 AM
DOCFIXIT
  • 18,828 POSTS
was all the testing done for P0748? Lots of wiring testing with OHM meter soleniod to PCM to verify PCM faulty. The code is not written in stone just a clue.
Mar 22, 2010 at 7:24 AM
NIKKIBRETT
  • 5 POSTS
Had a transmission specialist run all the diagnostics and he checked all the wiring and what not. Last hope is the PCM
Mar 22, 2010 at 11:50 AM
DOCFIXIT
  • 18,828 POSTS
Good Luck hope it works
Mar 23, 2010 at 8:07 AM
NIKKIBRETT
  • 5 POSTS
So after changing all the parts up to the PCM I went ahead and replaced the PCM had it reprogrammed and so far all is working great.
Mar 24, 2010 at 11:31 AM
DOCFIXIT
  • 18,828 POSTS
Great news will think good thoughts
Mar 25, 2010 at 5:41 AM
