I recently thru a P0748 code. Had the solenoid replaced, the relay switch, the harness and all the wiring replaced. Car worked great for 2 months and after a snowstorm it thru the code again. It goes through the shifting perfect then will go to limp mode. The transmission has been checked and is perfect. Nothing mechanically wrong with the tranny.
Is my next step to replace the PCM?
Mar 22, 2010 at 4:41 AM
