2001 Dodge Van no spark
TNOVELLI
Engine Mechanical problem
2001 Dodge Van 6 cyl Two Wheel Drive Automatic
no spark replaced coil crank and cam sensors has newer plugs wires and cap rotor
Jan 23, 2010 at 2:27 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jan 23, 2010 at 7:12 PM
TNOVELLI
i ahve checked resistance im getting voltage from coil and from crank and cam sensors everything seems to point to the coil but we just put one on and it didn't fix it and its kinda rare to have a defective part but im unsure.
Jan 24, 2010 at 12:31 PM
  • 75,988 POSTS
You got voltage to the coil, cam and crank sensors okay-If there's no spark coming out of the coil the ignition system is still dead-your last place to check is the computer
Jan 24, 2010 at 12:58 PM
TNOVELLI
ok thanks alot ill check it out tomorrow and see what happens and we even used a chrysler scan tool and there were no codes.
Jan 24, 2010 at 1:05 PM
