HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Van
Brakes
Wheel Cylinder
SPONSORED LINKS
2001 Dodge Van brakes
TIMWMASSISBACK
MEMBER
2001 DODGE VAN
Brakes problem
2001 Dodge Van 6 cyl Two Wheel Drive Automatic 70.000 miles
when I step on the brakes they don't release right away what causes this.
Tuesday, June 15th, 2010 AT 5:14 PM
BLACKOP555
MECHANIC
Restricted brake lines. Overfilled brake fluid resevor. Bad cap on brake fluid resevor or a misadjusted brake pedal.
If those are good the brakes may not be properly lubed and return springs weak
SPONSORED LINKS
Tuesday, June 15th, 2010 AT 10:00 PM
Please
login
or
register
to post a reply.
Related Wheel Cylinder Content
2001 Dodge Van Abs Brakes
Abs Brakes Go On When Vehicle Slowing And Coming To A Stop. It Feels Like It Doing So On The Front Driver's Side Brakes.
Asked by
fred dimeglio
1 ANSWER
2001
DODGE VAN
GUIDE
Wheel Cylinder Replacement
A brake system wheel cylinder is used to push against a set of brake shoes to help stop the car.
Brake Rotor
Im Having Trouble Finding A Brake Rotor For My Van. Its A 1995 Dodge Ram B3500 With 3600 # Front Axle. The Trouble Im Having Is That All The...
Asked by
ajy
2 IMAGES
1995
DODGE VAN
Can I Swap Brakes
I Need To Know If The Calipers On My 1973 Dodge Sportsman Camper Van Will Fit On My 1978 Dodge Futura Camper Van. I Got A New Van But The...
Asked by
rebkins18
1973
DODGE VAN
1983 Dodge Van Dodge B250 Van Brake Problem
I Recently Had Some Front Brake Work Done, Which Included New Pads, New Brake Hoses On Both Sides And A Caliper On Front Right. Shortly...
Asked by
randyb4269
1 ANSWER
1983
DODGE VAN
1991 Dodge Van Hard To Brake
Since I Bought The Dodge Van 1991 Always I Fix My Brakes, Front And Rear Never Had A Problem On Till Couple Month Ago, I Did The Brake Like...
Asked by
jhon1991
1991
DODGE VAN
VIEW MORE
SPONSORED LINKS
Brake Shoe and Drum Replacement
Bleed your ABS Brake System Correctly Video
Bleed and Flush Your Brake System Correctly
Online car repair manuals
