2000 Dodge Van spark plug wires removal
54,000 MILES • V8 • 2WD • AUTOMATIC
HKEVDOG4783
im trying to change my spark plugs but my wire boot s on so tight i cant get enough leveridge.to pull them out.theres a metal sleeve around them plus tight area. first tune up in 54000 miles. isthereatool?
Aug 14, 2009 at 9:40 AM
  • 110,248 POSTS
There isn't a special tool. All you can do is twist them and then try to see if they will come off. If you can get a pair of pliers in there and use the metal shield as a leverage point, you may be able to pry them off. Other than that, twist and pull.
Oct 11, 2009 at 5:55 AM
