2000 Dodge Van no horse power
144,000 MILES • V8 • 2WD • AUTOMATIC
CURTISS WATERS
My van has no horse power, and i can only drive
20 to 30 mph. When i put my down, it just bogs
down.
Apr 7, 2010 at 1:27 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 8, 2010 at 12:41 AM
